Put a new bert trans in today and sent old one away to get rebuilt. Hooked everything up and the clutch wont bleed at all. No pedal. I know the reservoir didn't go dry in the process. After trying several things we pulled the line off at the master cylinder and when the pedal was pushed a very small amount of fluid came out. Seems to be not enough though I have never investigated that. Is it possible the master cyl is now bad? We bled it to be sure air was out and we aren't getting air but not much fluid pushes out either. Im up for suggestions.
