Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Oil filter?
    Feb 2008
    581
    Default Oil filter?
    1060 or 1061 with drysump and cooler ???
    Feb 2012
    1,102
    not sure what filter those are but anything along the line of a fram hp6 is going to work. you dont want a filter that doesnt flow at least as much as the line you are feeding the engine with. keep in mind you will loose some flow through the cooler so my opinion is larger openings is better.
    Wix 51061R
    Dec 2007
    662
    JMO I wound not put a Fram on my lawn mower if you gave it to me. A lot of people might have good luck with them but Wix is the only choice IMO.
    Batavia, OH
    13,639
    Quote Originally Posted by RW57 View Post
    Frams will collapse.
    Atomic - 2
    Feb 2012
    1,102
    Just using it as a reference for opening size
    Aug 2009
    1,088
    Wix racing filters have heavier steel cans and a much more open/larger micron rating, flows better/ filters less than most other filters. jmho
    796
    Wix 51222R
    Jan 2008
    1,910
    Quote Originally Posted by cjsracing View Post
    Wix 51222R
    That's a fact Jack!
    you just got greased
    http://www.goddardwarrior.net
  10. #10
    Feb 2012
    1,102
    That's the one we use as well.
  11. #11
    FLANAGAN, IL
    879
    What is the difference between Wix 51061R and Wix 51222R? ~Thanks~
  12. #12
    Feb 2012
    1,102
    Smaller micron . steel cage. Higher flowrate
  13. #13
    Jul 2007
    538
    The 51061R is smaller than the 51222R. 51061R/51060R is made for a 350 stock block chevy mounted in stock location. Flows 28gpm and rated at 61 micron. The thread on this is 13/16-16. The 51222R is common for a remote mounted filter on a dry sump system. The thread on this is 1 1/2 - 12. This is a "large" filter. To go from a Wix part # to a Napa part # on just about any filter, drop the "5".
  14. #14
    1,016
    We've used the 51222R and had zero issues with them.
  15. #15
    FLANAGAN, IL
    879
    Thanks FlatTire for the detailed response.
  16. #16
    Dec 2008
    thedirtysouth
    4,014
    if your running a remote filter, I've had good luck with motorcraft filter that fits the 7.3 diesel
  17. #17
    Bob perice reccomends a wix # 51061 not the 061r any body know why??????????
  18. #18
    Aug 2009
    1,088
    Quote Originally Posted by wallbangerII View Post
    The non racing # 51061 flows much less and filters much more, I think the micron element was around 15 and it flows somewhere around 10 gpm. The 51061R is around a 60 micron filter and flows over 28 gpm as I remember. I was told, by a reputable engine builder, that you shouldn't run the heavier 50w oils and 50 multi viscosity oils in a standard filter under race/high volumn flows and pressures. PLEASE check this with WIX as it is just from an old bad memory!JMHO
  19. #19
    Jul 2007
    538
    Hpmaster has a pretty good memory!
    Straight off the Wix website:
    51061: 9-11gpm/21micron.
    51061R: 28gpm/61micron.
    Its always a compromise between engine life, flow, and filtering capability. Just depends on how you look at it and what you are trying to achieve. I imagine Bob Pierce is more concerned about clean oil than he is flow to the bearings which is why he recommends a more restrictive filter with greater pressure drop.
  20. #20
    Feb 2008
    581
    So what about the 52060R with anti siphone valve?
