Results 1 to 5 of 5
    Default Bunch of mini stock parts plus a Great D-Port Head
    Here is the list some things are not pictured. All parts are OBO
    Parts are for a mini stock.
    - Oval-Port head with Big Valves big springs Max Port & Polish and maxed shaved Solid head with Esslinger 580 lift cam $1000 OBO
    -Rear Sump Oil pan with pick up tube $100 OBO
    -Two 22x19 Ford radiators $100 for both or $60 a piece OBO
    -4 camber caster plates 2 matching that are just a couple races old with one bolt cut out made to fit $140 for that pair or $30 a piece for the other two or all for $175 OBO
    -Fuel Injected Intake ported out with 2in Carb Adapter nice stock style intake $100 OBO
    -12 Gallon fuel cell measure 12x12x9 in great shape and can $110 OBO
    -Accu Tech Oil Pressure and Water Temps Gauge $30 OBO
    -Schoenfeld Thunder Valley header surface rust new is $350 asking $150 OBO
    -Longacre kill switch $25
    -Floor mount brake and clutch pedal assembly $120 OBO
    -Rims
    3 13x7 4in Back Spacing
    6 13x7 2in Back Spacing
    2 13x6 2in Back Spacing
    $20 a piece or $175 and take them all some have tires some don't
    -10,000 RPM clutch fly wheel bots snapped as seen in pics. Could make a plate to go behind the flywheel disk where brand new before season and now only have about 75 laps on them asking $125 OBO
    -Kirky big boy seat without cover $60 OBO
    -Butler 18in seat with head rest $100 OBO
    All parts located in Kalamazoo, MI message me or ask on here or text me 269-744-7504
    1,008
    do you have pictures of the flywheel? there are none showing it. thanks.
    olin
    Text me I can send you pics
    Jun 2014
    3
    Still have wheels
    Illinois
    1,690
    I have sent texts but no response...what is still available?
