caster adjustments
I am working on the front end of my 09 bwrc and havent ever really adjusted much on front end setting and the car is pretty decent just trying to maybe make it a bit better. Anyways my question here is what will it do to the car if I increase the caster split across the front. I know on entry it will make the car turn in a bit better which wouldn't exactly hurt but what will it do on corner exit as I turn back right leaving the corner? Thanks in advance.
"Spindle Roll" will induce cross/wedge into the car as you turn to the right. To get an idea on what it does measure heights on the front (such as frame to the ground) with the wheels straight ahead, then turn them to the right and measure again. You should see your LF drop and your RF raise. Can be a good thing but too much of anything can have negative effects.
