Need help fast
Just put new bigger cam in and broke it in car has not been set on ground and moved until now ....when car is put in gear its laboring really hard to move like converter is bad or something but i know converter was good it had six weeks on it in another car we had just wandering if it could be something simple im missing because car sets in shop and idles and revs fine but under load in gear its struggling to moved someone said it could be way off on cam timing? Or valves are to tight has anyone ever had issues like this just dont wanna tear motor and trans out before ive ruled out everything else thanks in advance ...
probably to much duration for the compression...it will kill all the low end torque...common mistake is to get a too big of cam...
Broken oil pump lugs in the tranny??
Gator Engineering
