Fuel consumption
Has anyone on here ever calculated about how many gallons or pounds per hour a 2.3 ford is consuming ehile racing?
thrashperformance.com
Do you not know that in a race all the runners run, but only one gets the prize? Run in such a way as to get the prize. 1 Cor 9:24
There is way too many variables to come up with a number for that. RPM, Gearing, compression ratio, head work, timing, carb, header, intake, I can keep going but it's a waste of time.
I run a 10 lap heat & 15 lap feature on a 1/4 mile dirt track with a mild built 2.3L and never have used more than 2 gallons a nite.
Also depends on what fuel your running. Im averaging 5g a night on e85.
i run about 20-30 practice laps,3 laps qualifying,8-10 lap heat race and 25-30 lap main, i run sunoco 110 on a 1/4 mile track and use about 2 gallons
www.raceidaho.com
10+ laps packing, 5-7 laps hot lapping, 4 lap dash, 6 lap heat, 15-20 lap main. use 3 gallons 50-50 89/110. 2.3, 350 holley. 8000 rpm. 1/5 mile track.
olin
5 lap dash, 12 lap heat, 25 lap Main. 3/8's mile Dirt 4 to 5 gallons.
We also run a 2.3L Mustang Road Race car (ChumpCar) 5.5 to 6 gallons an hour
5 hot laps, 6 lap heat(about 10 laps with pace laps and caution), 20 lap feature - 3/8 mile track, 2.3 Hydrolic head, 8000 rpm, Holley 500, use at least 5-5.5 gallons a night, Shell 87 octane pump gas. No additives, just regular pump gas.
