shocks
wht kind of split valve shocks on a 2000 lb car? Any ideas? my car has straight shocks on it now..
mark41
What are you asking? You say "What kind of split valve shock". Are you asking what brand of shock or are you asking how much split? You also need to tell us what type of surface you run on as well as what type of car and are the shocks in the stock location etc. Just a bit more info needed.
not brand. what valving? its mostly dry slick occasionally it will be tacky. it is a tube chassis. coil springs in the front and coil overs in the rear. no the shocks are not in a stock location. fronts are 5 degrees inboard( leaning towards the ceneterline of the car and the rears are 10 degress.
mark41
