Results 1 to 7 of 7
    Jul 2007
    120
    Default Mastersbilt Front End? and rear bar ?
    Have there been any changes on front end settings? Car is 2010 S-7 Front end
    Is Mastersbilt still recommending same spacers between tie rod and rack, lower control and frame and tie rod and rt spindle etc?
    Just curious I have the old MB set up sheet that used to be on the website and just want to make sure still using same spacer sizes.
    Also what would you recommend starting the bar locations in the rear.
    Either hole locations or degrees
    Will be 604 crate having to weight 2400.00
    Track is tacky in beginning, slightly in heat and pretty dry in main. Does not take rubber.
    Batavia, OH
    13,640
    Send me a PM with email. I have an S7 sheet.
    I would start 3 down from top on rrt. 4 up from bottom on rrb. 4 down from top on lrt. and 4 up from bottom on lrb.
    Atomic - 2
    Dec 2007
    Michigan
    220
    MasterSbilt_Racer, I had tried to PM you in regards to the S7 setup sheets also, but your inbox is full and cannot accept anymore messages. Thanks
    Feb 2012
    Charlottesville, Va.
    174
    MasterSbilt_Racer, I tried replying too. Still full. You're a popular guy!!
    I wanna go Fast!!!
    Jul 2007
    120
    Thanks for the info. I tried to pm you also and got the full message.
    If you want to pm me your e-mail I will respond to you.
    thx
    I also tried to PM you and your box is full.
    Batavia, OH
    13,640
    OK guys.,.............
    Atomic - 2
