Rayburn with 2014 updates
Car is straight was checked on Rayburns jig in Feb. when updates were put on the rear also has wide right front option. Has alot of new parts they are as listed, pullbar, liftbar, double adjustable shocks lr and rf and revalved Koni's everywhere else. Has complete new wiring throughout car with new quickcar switches and master switch, new gauges, new tach, new MSD digital 6AL box with rev control and wiring harness and new coil. Rear end has been redone from wheel to wheel new bearings all around car also new brake calipers, rotors, brake pedal and master cylinders. Took car in on trade don't really need. Comes with 2 aluminum radiators and aluminum drive shaft. Car is a combo car set up 4bar swing arm by Rayburn was only raced twice after updates car has almost perfect body also. Can text pics if interested. $5,000 O.B.O. Thanks Gary. 606-792-6027 or home # is 606-447-3303
