Results 1 to 4 of 4
    Nov 2013
    17
    Default pro-dive and anti-dive
    How do u measure it? And what does it do
    Apr 2013
    152
    You measure it by drawing a line from the front upper a arm attachment point to the rear through the middle of the hiems then you measure how many degrees the rear is lower that the front (antidive) or the front lower than the rear (pro dive). It only affects the car while on the brakes. It keeps the car from diving on that tire (antidive) while on the brakes. Or vice versa. This is only a fine tuning tool.
    Is it very common to run more anit-dive in the left upper A-Arm then the right?
    May 2010
    632
