Yuck. Whenever i wasn't paying attention when i first started the right side was shorter than the left and when i would spin the tires it would try to spin out the wrong way. Never again. JMO.
That is a lot. I've never ran more than straight up. Sounds like you may have something else off on the car. I would definitely call your chassis builder. JMO
My uncle leads his right rear forward a 1/2" on his.3 bar car on an extremely slick track. I usually lead.my left rear forward at least a half an inch on everything I run.
I do adj trail of the rr a lot, 1 full turn or 2 full turns from my base seems to be enough to change my stuff quite a bit.To the original poster, I ran my grt first time last night, I cant imagine leading the rr. I am running a crate motor and square to the midplate was real tight. I put some trail in it after the heat and the car was stellar.
Thank you SCD your input is appreciated. We may try this tonight. Did it mainly free the car up entry or all the way through?
