Parting out few Mastersbilt Late Models
I am completely parting out a few mastersbilt late models. Please check our Facebook page for some pics at Bama Race Parts. I also buy, sale, and swap all the time and my inventory changes week to week. I will try to update list of what is sold and added every week. I do accept CREDIT CARDS, DEBIT CARDS, PAYPAL, or US POSTAL MONEY ORDERS. I am working on pics as we speak. BEST WAY TO GET AHOLD OF ME IS TO call or text for info or pics 256-577-3624 or 256-366-6543. I will do my best to get them to you as quickly as I can. I do not look on here much to check PMs or private messages!!
06 Masters smackdown chassis. Decking, ****pit, fiberglass roof, 32 gallon fuel cell, all brake lines, adjustable midplate, $1200
Pair blue plastic late model fenders $40
PPM Masters midplate $35
Open ramp over trailer. Has box on front with 1 row tire rack, winch. $2500 OBO
Weld-Valken beadlock wheels. 15x14 all 5 inch offset $125-150 range. Non beadlocks $50-85 range
Used foam mudplugs $5 each
Weld alum mud covers $15 each
Appleton 18 ¼ 3.4 power rack $300
Appleton 19 ¼ 3.4 power rack $300
Bert regular style trans $800
Reverse mount starters $85 each
Bert flywheels $40
Bert alum couplers $25
1 Race Only Masters RF 1 piece lower with adjuster $100 & LF 1 piece lower $75 both with balljoints
All bare upper control arms $10 each… 7 ¾, 8 ¼, 8 ½, 10 ½ split. $25 with balljoints & $40 with a Howe low friction balljoint
Speedway 26 inch alum radiator with hoses SBC $100
Longacre/Rebco gauge panels. $75 4 gauge $60 3 gauge
5 Inch recall tachs. QuickCar/Auto Meter $60-$85
Alum 2 lever shifters with linkages $35
Kirkey 16 inch intermediate seat black cover $100
Simpson blue belts $25
Wilwood reverse mount pedals and hand brake adjuster $200
MSD 6 AL boxes $100 each
MSD Blaster coils $20 each
Wilwood starlite rear hubs..Complete…spindle nuts, bearings, flanges, rotor $75 each
Wilwood starlite front hubs..Complete…spindle nuts, bearings, dust caps, rotor $75 each
TWM Bearing birdcages with all hardware…very few nights $425
Roller bearing cages, PPM LR, BSB RR with all hardware $350
(2) Winters quick chamges. 33/35 gundrilled axles, alum tubes, alum spool 486 gear, pinion plates (one new BSB ) $650 each
Winters quick change 34/35, alum tubes, gun drilled axles, 486 gear, alum spool $650
Winters quick change 34/36, alum tubes, alum spool, 486 gear, has 34 gun drilled axle but needs the 36 inch axle $575
Winters QC center section, 486 gear, alum lite spool $450
Ohlins Canister Gas Shocks from WAR with 5th arm rebound adj $2000 shipped
Afcos M2s Canister gas shocks with LRB shock $1600 shipped
Ohlins alum threded non adjustable front shock fresh $150
Integra IDA non adj alum threaded shocks from MARS $150 each
Ohlins rebound adj front shock. Smooth alum shock $150
Misc Afco 2100 series gas shocks $100 each with kit
Misc Afco oil shocks alum threded $50 each $60 with kit
Pair Mastersbilt S7 spindles $150
Several Mastersbilt Smackdown spindles $40 each
Chrome stagger stick $25
Bead breakers $25 each
Misc coilover springs, 10s, 12s, 14s. Hypercoils $15 each Afcos $5 each
CJR alum power steering pump, Oval craft tank, head mount and lines $200
Alum power steering pump, alum tank, block mount and lines $175
Steel GM power steering pump, alum tank, block mount, and lines $150
KRC steel power steering pump and pulley $75
Acept carbon fiber driveshaft with 8 inch yoke. 38 inch $400
Coleman 38 inch alum driveshaft and yoke $100
Coleman 35 inch alum driveshafts and yokes $100 each
Mastersbilt smackdown 5th arms with hardware $65 each
New Longacre battery power switch $25
2 sets Shoenfeld headers 23 degree $100 per set
Pair Wilwood superlite calipers with pads for 1.25 rotors. 3.5 mount space $100 for pair
Pair Outlaw NDL calipers with pads for 1.25 rotors. 3.5 mount space $100 for pair
Pair Wildwood NDL calipers with pads for 1.25 rotors. 3.5 mount space $120 for pair
Pair GRT dynalite calipers with pads for 1.25 rotors. 5.5 mount space $100 for pair
Fuel line #10 blue with fuel filter $35
Fuel return line #8 blue (regulator back to fuel cell) $25
Used battery power switch $15
Used toggle style switch panel $15
Lead weight $.75 per lb
Wehers alum J bar slider mount. One mounting hole $25
Misc steel J bars with adjusters range 18 to 20 inch centered. $50 each
Mastersbilt 6th coil assemblies $50 each
Quick Spin tire tool $25
Misc 4 bars with heims. 12s, 13s, 14s, 16s, mostly. $15 with heims $5 without
Rear End fill cans $25 with lines $20 without
Oval craft fill can $25
Oval Craft dry sump breather tank $40
New white hood scoop $30
Used Dominator carbon fiber hood scoop $20
Used tire groover $40
Tire groove stand $100
Shock Nitrogen bottle with gauge $125
Bilstein gas shock gauge $60
15 Inch alum steering wheel with hex coupler $25
Sweet 15 inch steering wheel with Sweet splined coupler $35
Sweet 15 inch steering wheel with QuickCar splined coupler $35
PPM chain limiter $35
7 inch tire buffer disc $20
Quick change gear sets. Range from 630 to 715. May have some in 500s too. $25 per set
Alum quick change drain pan $25
SBC Engine Parts
377 shortblock. 509 casting # 400 block (2 freeze plug block), 4.155 bore, head studs, 4 bolt main block with billet splayed caps, Eagle crank, 6 inch Eagle rods, SRP dome pitons, roller cam, lite weight balancer. $2500 obo
355 shortblock, 6.125 Oliver billet rods, CP flattop pistons, GM steel crank, one piece high nickel block, roller cam, lite balancer $2500 obo
Dart steel 215 runner heads. Roller springs, 7/16 studs, guideplates steel retainers & locs, 49cc, $600 obo
Dart Alum Pro 1 Heads & Edelbrock 2975 Intake, 215 runner heads, Roller springs, 7/16 studs, guideplates steel retainers & locs, 64cc, $1000 obo
Brodix Trac 1 Alum Heads & Edelbrock 2975 Intake, CNCd, 215 runner heads, Roller springs, 7/16 studs, guideplates steel retainers & locs, 64cc, $1000 obo
Comp Cams .840 roller lifters sbc $150
Comp Cams sbc 1.5 ratio stainless rockers, tall poly locs, Coleman stud girdle, $250
Crane sbc alum roller 1.5 rockers and tall poly locs $100
New alum polished valve covers $60
Used vortec valve covers needs one bolt $40
Used alum black powder coat valve covers, has one small weld repair $40
Willy’s 750 alky carb with fuel log and Barry Grant fuel regulator $500
C&S 750 alky carb needs kit $150
Alum breather top & bottom with sure seal & R2C air filter $60
Wilson Manifiols 2 inch carb spacer $100
Alum short style water pump pulleys with belts $50
GM 16 inch 4 blade fan $20
GM alum short style water pump $35
set of s7 spindles, quick change gear pan, stagger gauge, tire groover, several wheels (2 beads left, 3 nons left), MSD pro billet distributor and wires, all sold
all wheels, both 35 inch driveshafts. RC2 breather assembly, KRC power steering pump all sold
Bert trans, TWM roller birdcages, ppm chain limiter, masters 6th coil, returen fuel line, sbc pulleys, ppm masters midplate, C&S carb, bert drive, bert flywheel, shacker screen, all msd boxes, speedway radiator, peterson 3 stage pump, butler built dry sump tank, alum power steering pump with oval craft tank and lines, both masters 1 peice lowers ALL SOLD
Place your parts on www.RacePartsTrader.com for no cost. Just use the promo code: Launch after the ad is placed. Promo code valid through August 31st.
