2005 Rocket 2" black front, Winters 4.86 rear with magnesium center, 5:18 gear, TWM billet bearing birdcages, CV Products billet aluminum J bar, Woodward 1-1/8" 4 link bars w/ new heims, Wilwood magnesium hubs (just repacked w/ Amsoil synthetic grease & new seals), Rocket uppers & lowers with Howe ball joints, Wilwood master cylinders & calipers, ATL 32 gal fuel cell, Kirkey 15.5" full containment seat, Telltale digital tach, Autometer water temp, fuel pressure, oil temp, oil pressure gauges, water pressure light, Woodward collapsable steering shaft, rack( jsut repacked w/ Amsoil synthetic grease & new boots), and servo, DIS American Racer tires & PRO shocks, Weld RF & RR beadlocks with cover, Weld LF & LR non-beadlock, Arts aluminum radiator with -16 AN top hose, Trick shroud w/ Hendren 2 blade fan, 16v Turbostart battery, direct wired transponder, Onboard fire bottle system with braided lines, 2006 DIS sealed 602, Stealth carb, GM distributor with DUI module & MSD cap & rotor, Scott wires, Holley fuel pump & regulator, Beyea headers, KRC power steering pump & serpentine system with idler pulley, Brinn aluminum trans, Brinn magnesium bellhousing, crate flywheel coupler, Powermaster mini starter, Trick carbon fiber driveshaft, Trick roof. Some extra suspension parts. Car is complete. $8000. Pics available upon request. Located in Georgetown, Delaware. Call Dave Magee (302)-604-9560 or davemagee96@yahoo.com
