2006 Rocket
2006 Rocket 2" blue front, Needs front clip, Winters 4.86 rear with magnesium center, 5:24 gear, TWM billet bearing birdcages, Rocket J bar, Starlite 55 polished hubs with angular contact bearings (just repacked w/ Amsoil synthetic grease & new seals), Rocket uppers & lowers with Howe ball joints, Wilwood master cylinders & calipers, Jaz 32 gal fuel cell, Kirkey 15" seat, Telltale digital tach, Autometer water temp, fuel pressure, oil pressure gauges, water pressure light, Woodward collapsable steering shaft, rack( jsut repacked w/ Amsoil synthetic grease & new boots), and servo, DIS American Racer tires & PRO shocks, Duralite RF & RR beadlocks with cover, Weld LF & Keizer LR non-beadlock, Afco aluminum radiator, Trick shroud w/ 15" 6 blade fan, Carter fuel pump, Shoenfeld headers, Sweet power steering pump & pulleys, Bert Ballspline trans, Bert bellhousing, crate flywheel coupler, Gears Unlimited starter, Coleman aluminum driveshaft, Trick roof. Some extra suspension parts. Car is mostly complete less engine & body. Pics available upon request. Located in Georgetown, Delaware. $3500. Call Dave Magee (302)-604-9560 or davemagee96@yahoo.com
