HuckleberryB4
Say you're using a 3" Christmas tree style with and you're using the first inch to gain rate. Let's say that inch equals 200 lbs of rate gained. Now we cut off the top 1/2" BUT use shims to make up the 1/2" we just lost, so the bump is being engaged at the exact same travel. Will that inch now equal the same 200 lbs or will it be more? My guess is that it will equal more, since you are using more of the bulk of the bump?????
You stiffened the bump just like you stiffen a spring when you cut coils off it.
Atomic - 2
