Floating RR on Fastboys setup.
Other than buying the leaf spring floater, how are you pure/street stock guys floating the right rear? Something not real noticeable, because no one around here really knows about it. I've got a few ideas, would just like to see what else people have used.
i used a piece of 3 1/2" pipe cut longways and welded back together on the axle tube where its slightly loose ....its the same width as the lower spring plate.....drilled a hole in it and used a grease fitting from an old u joint,,then i cut 2 pieces of pipe 1/2" wide and welded them to axle tube on both sides of it to stop sideways movement..welded a spring perch to it and had to kinda rebend the u bolts around it.
