Results 1 to 10 of 10
Thread: Sell out
    Nov 2009
    193
    Default Sell out
    Weld wheels: NB w/tabs $150, BL $200, covers $15 ea. SOLD!
    Gears: lightweight $125, STD $45
    Pop Rivets: blue & silver SOLD!
    Rocket skid plate $30 SOLD!
    Rocket RR short bar setup $60 SOLD!
    Eibach XT springs $50 ea (14"-175 & 12"-275, 375)
    Integra take-up & divider $40
    Fuel jugs $10 ea
    Rocket spoiler $60
    Mason starter $75 SOLD!
    K&N air cleaner kit $125 SOLD!
    Air cleaner scrub bags $15 SOLD!
    R2C air cleaner kits $75 ea SOLD!
    Gear drain pan $30 SOLD!
    KRC fuel log $10
    Tire pressure gauges $10 SOLD!
    Lug wrenches $10 SOLD!
    Fast Shaft 2" steel driveshaft $50
    Bead roller $30
    Winter's drive flanges $40
    Brake bias gauges $30
    Spanner wrenches $10
    Chevy water pump $50
    MSD blaster coil w/bracket $25
    Safety wire kit $15 SOLD!
    WD-40 sprayer $25
    Hoosier tires
    4 link bars $10 ea
    78 gallons late model plus fuel $600
    2003 Vintage 26ft enclosed trailer $5000
    Call or text: 443-340-6567 or 443-605-4702
    Email: rocket21j@gmail.com
    Nov 2013
    137
    where are you located
    Nov 2009
    193
    Westminster, MD
    Nov 2009
    193
    To the top
    Aug 2007
    388
    Horizontal or vertical brake gauges? What brand & size?
    Nov 2009
    193
    They are the ones you screw into the caliper to check at the shop.
    How long was the link bar on the Rocket RR short bar setup? Is this a new Rocket setup?
    Nov 2009
    193
    Yup. If I remember right, it's was an 1 1/4" shorter then standard
    Thanks for the info. I will give it a try.
  10. #10
    Nov 2009
    193
    To the top
