RH-5R handheld radio- A Great Buy!
The Rugged Radios 5 Watt Handheld Radio (RH-5R) was released 6 months ago and has quickly become our most popular handheld radio. Perhaps its most important feature is the dual band (VHF/UHF) functionality, giving you the ability to communicate with both frequency bands, something most radios are incapable of. The RH-5R features 128 programmable channels, over 40 of which are already pre-programmed with popular race frequencies. These include Weatherman, BFG Relay, Baja Pits, Best in the Desert, KOH, SCORE, etc. The RH-5R is face programmable, though if you're not feeling up to it you can always request to have us program any additional channels you want, free of charge. The RH-5R is loaded with many great features:· 5 Watts· Dual Band (VHF 150MHz-174MHz) (UHF 420MHz-470MHz)· 128 Programmable Channels· FM Radio (65MHz-108MHz)· Mini LED Flashlight· Emergency Alarm Function· DCS/CTCSS programmable (Tone Codes)· Lapel Mic and Earpiece· Built-in Belt Clip· High Capacity 1800mAh Lithium-Ion Battery· Battery Charger· VOX (Voice Activated Transmission) (disabled by default)· Battery “Save” Function (disabled by default)· Selectable Scan Mode (disabled by default)· Offset Function for Repeater Access (disabled by default)· Dual Watch / Dual Reception (disabled by default)The average user can expect about 8-10 hours before requiring a recharge. If battery longevity is a concern, we offer a battery eliminator which plugs straight into a cigarette lighter receptacle.With 5 Watts of power, the RH-5R has a range of about 2.5 miles. This can vary depending on your line of sight and density of surrounding terrain. To increase the range of the RH-5R, many will upgrade to a larger “Ducky” antenna. This XL “Ducky” antenna screws on easily, and can increase the range of the radio by 15-20%. Part of the RH-5R’s popularity can be contributed to its variety of accessories available. One of our bestselling accessories is the Radio Box we designed to mount the RH-5R securely in your vehicle, and our bar mounts make the mounting process super easy.There are plenty of activities that can benefit from having a RH-5R, and its combination of affordability (especially compared to other handheld race radios), features, and dependability make it a wise choice for those browsing the handheld radio market.RH-5R product page
(888)541-7223
Forum members receive 10% off retail! Use coupon code 4M10
Keegan Kincaid in his Stadium Super Truck with a RH-5R!photo credit: SST Facebook page
(888)541-7223
