Results 1 to 2 of 2
    Default All Aluminum 410 15 Degree
    410 cubic inch 15 degree aluminum super late model motor. Dart 4.145 aluminum block, Crower pro series 3.800 crank, JE pistons, Dyers coated rods, T & D shaft rocker system, PSI valve springs, Trick Titanium valves, Custom Cams camshaft, PBM/HVH fully cnc'd 15 degree heads, Edelbrock intake, Jones pulley system, CV products billet fuel pump, Pro Pan dry sump oil pan, MSD billet distributor, Schoenfeld tri-y headers. Original Russell Baker motor. $12,500. Call 606-668-3735
    Joe's Race Parts
    From Mild to Wild...
    and Everything in Between
    http://www.191speedway.com
    http://www.joesraceparts.com
    Need to sell.
    Joe's Race Parts
