Results 1 to 3 of 3
    Mar 2010
    21
    Default 2015 BeakBuilt Outlaw Modified Show Car
    This car was built and assembled by Close Racing Supply in Eldred, PA for Quick Car Racing Products booth at PRI show. Absolutely the best parts were installed on this high quality modified. Frame was constructed in North Carolina by Dave Reutimann Enterprises and finished by CRS. Frame is powdercoated white by Absolute Powder Coating. All bolt on components were coated white or pepsi blue. Body and Interior is Chevron blue and built by top notch fabricators at CRS. Body is completely DZUS on w/MD3 rockers, Flexible composite body braces, + more. Front suspension has small diameter LF ball joint adjustable uppers, AFCO pinto spindles w/supports, Beak Built tubular lowers w/LF ball joints, CRS centerlnk, Scalloped tie rod tubes w/chrome moly ends, Sweet 6:1 steering box, Beak Built adj shock mts, Wehrs swivel cups, + more. Rear suspension has BSB bearing birdcages, BSB brake floater, BSB climbing pinion+frame mts, BSB j-bar, BSB XD slider, Beak Built pull bar mts, Quick Car pull bar, Scalloped 4 bar rods w/chrome moly ends, BSB RR brake clamp, Bearing chain holders w/bushing chain mts, + more. (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit has Kirkey 16" full containment seat powdercoated white, Quick Car seat belts, Quick Car gauges in fiberglass gauge panel, Quick Car LCD recall tach, Quick Car switch panel, Quick Car brake bias gauges, AFCO brake pedal+master cylinders, AFCO bearing throttle, MSD 6AL digital box w/coil, Quick Car wiring harness, RF electric shut off, All Star crank brake adjuster, All Star 2 lever shifter w/lock, + more. Brake components include AFCO aluminum metric calipers, AFCO pillar vane scalloped rotors, AFCO brake pads, powdercoated blue steel brake lines, #3 black coated flex lines, + more. Other components include RCI 22 gallon wedge cell powder coated white, Fragola black fuel line+fittings, Beak Built midplate, AFCO 26" double pass LW narrow radiator, radiator shaker screen, XS 16 volt LW battery, Quick Car battery cable, Quick Car under car LED lighting kit, Firewall power steering tank w/lines for rear mt pump, Rearend fill tank, All Star oil cooler w/#10 lines, + more. Rearend is Winters magnesium quick change with following options: coated black, 4:11 8" ring+pinion, gundrilled lower shaft, aluminum yoke, short cavity rear w/6 bolt cover, REM polished ring gear+bearings, Ultra LW aluminum spool, angular contact spool bearings, low drag seals, 6 rib bell w/inspection plug, gundrilled axles, + more. Winters Platinum series grand national rear hubs w/angular contact bearings and scalloped drive flanges. Shocks are AFCO base valve silver series tuned by Bob Harris Enterprises w/10" LR shock option along with AFCO springs. AERO white wheels w/ Hoosier emod tires. Nothing was spared on this car! All top notch equipment! Selling as a complete roller with all the above listed items. Contact Joel at Close Racing Supply (814)225-3250. Car is located in Eldred, PA. Please only serious inquires only! If you have a strong modified race program and are looking for the best built car give me a call! Also available with this car is Winters Falcon roller slide transmission, Falcon bellhousing+starter, Wiles carbon fiber shaft, + Beyea nickel coated Tri-Y headers. For pix check out add on racingjunk.com #182344589
    Mar 2010
    21
    If your looking for a well built high quality modified and have a solid race program give Close Racing Supply a call at (814)225-3250. This car might be priced less than you think! Check out Racing Junk add for more detailed pictures.
