Results 1 to 6 of 6
Thread: 2010 gen x
    Default 2010 gen x
    Just bought a 2010 gen x looking for some help with numbers ( ride heights, springs, left and rear weight, bite, etc...) Will be running 604 with AR 56 or Hoosier 1600 on rear. The car has bracket extensions on both bottom link mounts on frame, what do these do?
    Jul 2007
    Blue Ridge, Ga.
    26
    What's your email and I will send you the set up sheets dtchdiger?
    Devin "Dirt Demon" Stuart #20
    Jun 2007
    3,123
    Most folks find the Gen-X baseline setup to be way too tight for a crate. You'll likely need to do some things differently to go fast when the track is heavy.
    Jun 2007
    3,123
    Quote Originally Posted by dtchdiger View Post
    As I looked back at this I realized I didn't answer one of your questions. The bracket extensions are there to get you the standard GenX bottom lengths of 16". Standard Gen-X lengths are 16" bottoms 18.25" tops.
    Jun 2012
    5
    Hi Matt49, I sent you a private message but it said that your inbox is full and you cannot receive any more messages. Is there any way you could check and see if you received it. Or do you have an email I can reach you on.
    Thanks
    Jun 2007
    3,123
    I freed up some space. Try it again.
