Brinn, Appleton, Late Model Parts
-Brinn trans. No cracks or welds. Comes with brackets for shifter rods. Not sure how long since rebuild but haven't run into any problems with the clutches yet. Can send pictures. $800
-older aluminum 5 hole non beadlock 14" wheel with siped and grooved d55 wrs2 tire. $50
-19.25" Appleton rack with integrated servo. Works great. $275
-26" triple pass aluminum radiator. $75
-(2)in car fire extinguishers. $25 each
-10" left late model spindle. $20
-9" right late model spindle. $20
-8" right late model spindle. $20
-GRT aluminum Jbar frame mount. Scalloped with threads. $10
-Aluminum quickchange torque arm mounts with damper shock holes and bolt. $5
-power steering reservior. $10
-Wide mount aluminum SRP brake caliper with pads. $25
-(2)10.5" Afco upper control arms with ball joints. $10 each
-23" steel throttle rod with clip on end. $10
-(2) aluminum beadlock rings. $5 each
-94" powersteering hose with 90 degree ends. $10
-350lb 10" afco spring. $5
-475lb 10" afco spring. $5
-500lb 10" afco spring. $5
-225lb 12" afco spring. $5
Can send pictures of everything. Can do a better deal with larger purchases. Call or text for questions or more information. (402)480-1238. All other reasonable trades for anything late model related will be considered.
