Results 1 to 5 of 5
    Default Wissota race car difference
    Anybody know what the difference between a wissota frame and a regular frame?
    Aug 2011
    Dresser Wi
    851
    As far as late models go you can run the big name chassis brand and shock combos as the big boys its just different motors as far as i know
    Batavia, OH
    13,636
    Quote Originally Posted by Larry Timms View Post
    Some Wissota frames had more engine setback from MasterSbilt.
    Atomic - 1
    May 2008
    801
    The Wissota car has 104" wheel base, usually late model is 103", the extra inch is added to the front of the stub to help with the steel head motor. From the midplate on back everything is the same.
    May 2013
    573
    They've also taken away the set back rule as I understand, if you do run it set back you have to add lead to the RF of the car.
