Results 1 to 6 of 6
Thread: Starter failure
    Jul 2007
    california
    109
    Default Starter failure
    Anyone else having starter failures on a standard brinn reverse bel housing . Starter still runs but looses pushing power to push and engage the idler gears. I've been through 5 starters this year different brands. All do the same thing after a while is this common? I take them and get them gone through at local electric shop they always work for a very short period. I mean like adjusting the valves and they quit again. Anyone have a solution ?
    Jul 2007
    california
    109
    Also. It's a brand new bel housing this season. I've had more trouble with one motor than the others. Am I doing something wrong ? It's same problem in two different cars
    USA
    1,261
    Make sure that your bellhousing isn't warped.
    1,903
    Make sure you pump that grease fitting full. Not keeping that thing well lubed can cause what you are describing
    Dec 2014
    pa
    218
    never had any luck with redoing a race starter, I actually bought a new starter on ebay from dbr starters there good to 15-1 compression ,3 years on a 11.5-1 358cid no problem.145.00 ebay motors, dirt late model starter. check it out
    in a van down by the river
    1,892
    make sure you cover them with a bag when washing.
    I build my own starters, but I cover them when washing and take off the solenoid cover about once a month and clean the plunger, and the 2 contact ears with emery cloth.
    Does starter engage or click, or does it go out to engage the idler gear and just quit?
