18* small block chevy cheap!!!!
i have a 420 steel block , Aluminum heads by Chapmann for Vic Hill ,shaft rocker assembly , has aluminum water pump , pulleys , MSD dist. , Eagle Crank , Eagle Rods , NEW JE Pistons , rings , bearings , roller cam and lifters , double roller timing gears and chain , needs oil pan and carb .... still in the bag it came from engine builder in ... just want gone . can no longer use because now run crate motor .. cheap deal $5,500
also have numerous quick change gears that i cant use $20.00 a set
2 -7" and 1- 9" - pro double adjustable shocks completely FRESH WITH DYNO SHEETS ALL 3 FOR $350.000 WE can not RUN THEM THATS WHY IM SELLING WQANT IT ALL GONE GIVE ME A CALL 419-934-5086
all the numbers are stamped on these heads visible , titan valves ? , jesel shaft rockers . just dont need any longer .FRESH MOTOR for someone
