Check It Out!!!!!
Check It Out!!!!!!!!
1. Sweet Rack 4.0 .210 servo New 2013 SOLD!!!!!!
2. Mag Bert Ball Spline SOLD!!!!!!!!!!!
3. Brinn Chevy Mag Bellhousing SOLD!!!!
4. Reverse Mount Starter $130
5. Coleman Aluminum 38" Driveshaft (No Yoke) SOLD!!!!
6. COMPLETE OIL SYSTEM: Barnes 5 Stage Oil Pump with Pulley, Sweet Tandem Power Steering Pump, All the Oil Lines, Deck Mount Oil Cooler, Peterson Oil Tank with Horizontal Oberg Filter, Peterson Remote Filter Mount $1750
7. Chevy Afco Radiator 19x27 $100
8. Kirkey 17" Seat with add on Halo SOLD!!!!
9. Ohlins Shocks RF LMP, LF LMP, LR LMP, RR LMJ Fresh (Look Like New) Ran on a MastersBilt $2000
10. 1.590 Stealth Carb (Lite Weight) 50 Laps since new SOLD!!!!!!
11. Misc. Advanced Cannister Shocks Call For Details and Pricing
12. ATL (26 gal) Lite Weight Aluminum Fuel Cell with cage for MastersBilt SOLD!!!!
13. ATL (15 gal) Lite Weight Aluminum Fuel Cell with cage for MastersBilt $450
14. MastersBilt (26 gal) Wedge Angle Fuel Cell with Cage SOLD!!!!
15. MastersBilt (22 gal) Wedge Angle Fuel Cell with Cage SOLD!!!!!!!!!!!!!!!!
16. Tiger Low Drag Thermal Coated 4.86 Quick Change
33"/35" axle length, REM ring & pinion, PPM pinion plate, Black Aluminum Tubes,
BSB Aluminum Birdcages (Came out of a MastersBilt) SOLD!!!!!!!!!!
17. (3)15x12 NBL Wide 5 wheels with IMCA Tires SOLD!!!!!!
18. (1)15x12 Wide 5 Bead Lock wheel with IMCA Tire SOLD!!!!!!!
19. Brinn Transmission SOLD!!!!!
20. Brinn Ford LW Aluminum Flywheel HTD Drive $200
21. Brinn Ford LW Steel Flywheel HTD Drive $175
22. Peterson 5 Stage Oil Pump (Bellhousing Mount) with Pulley in Excellent Condition SOLD!!!
23. Ford RDI Aluminum Block 9.200 Deck with Lifters (302 Mains) $3000
24. Ford RDI Aluminum Block 9.200 Deck with Lifters (351 Mains) $3000
25. IMCA Ford Spec Heads (One Head needs minor Repair work from Blown Head Gasket) SOLD!!!!
26. Ford MSD Distributor for 8.700 Deck (302) $175
27. Afco Double Adjustable LRF Shock $275
28. Fast Shaft 2" Lite Weight Moly Driveshaft 35" long (No Yoke) $75
PRICES DO NOT INCLUDE SHIPPING COSTS!!!!
CALL FOR MORE DETAILS!!!!
THANKS
David (712) 779-0116
Chris (712) 779-0304
tttttttttttttttttttttttttt
tttttttttttttttttttttttttttttttttttt
Whats your bottom dollar on the brinn trans?
Updated thanks!!!!!!!!!!!!!
