Virtual Crew Chief v2.04
Version 2.04
* New Features
- Added calculators
- Shock travel info
- Bump stop data for front
- Dual spring data for RF
- Wheel offset
- Swaybar info (Asphalt Cars)
This software is for keeping track of all your chassis setup information. It can keep multiple setups for different dates, tracks, conditions, cars, etc. Some of the features are listed below.
- Weight Calculator (Front%, Rear%, Left%, Cross, Bite, Total)
- Records Tire/Wheel Data (Size, Compounds, Temps, Rollout/Stagger, and Pressures)
- Records Frame Height Data, Spoiler Data (Height/Angle), and Travel Data
- Works with multiple rear suspension types (4-Bar, Swing Arm, 2-Link, etc.)
- Save shock data (Comp, rebound, psi, serial number)
- Multiple suspension save points for front and rear info.
- Record multiple setups for various tracks and conditions.
- Setup recommendations for various types of handling problems.
- Record maintenance information (Laps on engine, oil, tires, timing, etc.)
- Built in calculators for helping find MPH, gear, RPM, diameter, stagger, etc.
- Notes section for any other information you wish to save with the setup.
- Two car lap timer to track multiple cars for a session.
- Any updates to the software will be free for the first year from date of purchase. (Fixes, additional fields, changes, etc.)
- Software can also be customized for any type of racing. (Additional fees may apply)
Lap timer works via computer and user pressing a key on the keyboard or mouse to record each lap. Much easier than using two stopwatches and it also saves more information. Software works on all types of rear suspensions. Check out more screen shots and features on our website at the link below.
http://www.n-motionsoftware.com/programs.html
If you would like to purchase the software online and download your copy just scroll to the bottom of the page and click buy now.
Visit the contact page on our site if you have any questions, issues, or comments. You can also order by check, money order, credit card via phone.
