Results 1 to 5 of 5
Thread: 9" floater
    Sep 2009
    831
    Default 9" floater
    How much oil are should you use in a floater 9" of you use the inner seals?
    Jun 2007
    140
    I've always used 3-4 quarts with inner axle seals and never had an issue.
    DEPENDING on gear ratio 3.5 to 5 qts
    Jul 2007
    3,224
    Quote Originally Posted by slim269 View Post
    Why would the gear ratio matter?
    5 qts would be above the axles.
    3 qts with seals
    Sep 2009
    831
    Thanks everyone. I had 4qrts with seals and had some leakage and venting problems.
