Results 1 to 9 of 9
    Default brass filings in gear oil of Winters rear
    Any ideas on where to check? Thanks
    How many laps since its been last split apart/rebuilt? Take a magnet to these shavings and verify if you haven't already...
    Feb 2012
    1,102
    Pretty sure the only brass would be the ring gear backer. Like above stated magnet to double check . Steel can get heated to a brass like color. Either way take it apart an look.
    Aug 2009
    1,088
    The gear backer thrust button is the only brass I can think of in a Winters. To wear that you have other issues in the carrier bearing I would think. Pretty sure you need a complete tear down and overhaul.
    Batavia, OH
    13,676
    Quote Originally Posted by hpmaster View Post
    Or someone cranked it down during a bolt check! lol It has happened!
  6. #6
    Aug 2009
    1,088
    Quote Originally Posted by MasterSbilt_Racer View Post
    Yea I will give you that. LOL
  7. #7
    Dec 2007
    Red Dirt USA
    1,024
    Or the fittings for the vent and oil filler lines!
  8. #8
    153
    a winters rear has nothing brass in it unless it has the low friction ball bearings on the spool or pinion I have seen the spacers for the balls break ,the side preload spacer is hardened steel in a winters, frankland has the non adjustable brass spacer on the side bell
  9. #9
    Feb 2008
    colchester il.
    2,172
    I just pulled the tubes out of an older winters qc and it had a brass backing plate. who know if it was oem or a replacement.
