Results 1 to 4 of 4
Thread: Gear oil Q
    Aug 2013
    12
    Default Gear oil Q
    How much gear oil should be put in a 9 in rear end. Also what weight, syn or non. 2008 shaw Midwest Modified. Thanks
    Sep 2011
    Central IL
    504
    Around 1 gallon should do. Redline Heavy Shockproof is about the best there is for a 9".
    #72W U.M.P Stock Car
    We got better gear life out of 140 weights from tractor supply than the syn 90 weights.
    Jun 2013
    307
    85w140 Valvoline with not one issue. I have always used 5 qts in my floater without inner tube seals and never had an issue.
