Results 1 to 9 of 9
    Aug 2010
    169
    Default Ignition switch issues
    Anyone else having ignition switch issues? I've had 3 come apart in about 14 nights of racing. The contact come apart and usually it happens mid corner, shutting the car off.
    I've been using Longacre ones, but someone told me about a switch made now that is more heavy duty than the typical pronged switch.
    Thanks
    I use 4 prong two position switch. If you buy a quality switch panel it will have a switch like this on it. Always use screw connections not spades. I would suggest a cole hersey switch. They are spendy.
    Aug 2010
    169
    I have been using the screw connections.
    Thanks for the advice, I'll look into it.
    May 2012
    334
    i have had the same problem with that switch what we found is the plug is heavy and if it is not wire tied tight some were it will bounce and pull the switch apart.
    Oct 2014
    22
    Go to a Caterpillar dealer and get a switch.
    Jun 2010
    Bakersfield,Ca
    566
    Napa 30 amp push pull.No more problems.
    Info compliments of Larry Shaw school.
    Gator Engineering
    http://www.ebay.com/itm/HEAVY-DUTY-7...-/331366216551
    This is the style Dave is talking about, they work great ! Napa and Carquest usually stock them .
    Aug 2010
    169
    Thanks guys!
    18
    Purchase a Honeywell or Eaton sealed IP67/68 DPST toggle switch, wire the circuits in paralell and never worry about it again. The pressure washer is what really kills toggle switches, even the ones with rubber boots.
    http://www.mouser.com/ProductDetail/...CrknQoRWWtI%3d
    NOTE: The good sealed toggle switches can be identified by a small orange gasket at the base of the toggle shaft.
