358 Late model on alcohol running out of fuel(running lean and getting warm/hot) on the track. Has happened with 2 different engines and at 3 different tracks. Have tried 2 different carbs, new fuel pump, new regulator, new fuel line, new fuel filter (yes, it's in right). Idles fine and good fuel pressure in garage or pits. 4-6 psi at idle, 10-12 at 3500 rpm. The driver has reported 3-5 psi on the track at wot.
