Results 1 to 8 of 8
Thread: need fwd bite
    Jun 2015
    10
    Default need fwd bite
    First year in a three link having some problems getting it setup. Car drives good now after some adjustments over the last 5 races.still lacking fwd drive.55 rear 55 left 49 cross 68 lbs lr bite. springs lf1000 rf1100 lr225 rr175 shocks lf5-3 rf3-5 lr8-2. rr3-5 solid top link@ 18* lowers both@7* 1 inch stager in front 3.5 in rear. RR set back 1/2 inch. 3/8 mile mostly dry. Any help greatly appreciated
    Jul 2007
    3,224
    lot of stagger and trail depending where your measuring
    Jun 2015
    10
    Rear trail is only way we could get it to turn burnt the RR off two weeks in a row . increased lr bite got a push.offsetrear to loosen under throttle
    Jun 2015
    10
    Rear steer measured from a factory hole in the back of the metric framerail
    May 2015
    856
    I would try a 250 in the LR. That will free up your entry (off the gas) and give you more forward bite.
    Dec 2008
    thedirtysouth
    4,017
    1st thing I would do is pull a center line and check my static rear end alignment.
    Pa
    486
    With 55% R you shouldn't be having forward bite problems. I would first square up the rear leading the rear will give false indication of handling. Also I would ditch the 8-2 LR shock and go with a straight 3 or 4 valve shock your killing weight transfer needed on a 3 link car also get the RR on a straight 4 or 5 valve. Also with out knowing anything thing else as far a weight, shock travel and kind of car I think the 175 is a little soft and with your shock combination your holding the car and weight to the right. Don't be trying to run it like a late model these are two different animals.
    Guysville, Ohio
    391
    You need more cross weight. Try to get it to 52% at least.
