Results 1 to 6 of 6
    341
    Default Metric front track width, stock vs impala spindles
    Its been over 10 years since I had a set of stock spindles but I thought maybe someone on here could answer my question. On a metric stub, when switching from the stock spindles and rotors to camaro or 80s impala spindles, did it make the front track wider? I honestly dont remember. Thanks
    Nick
    Somewhere around 1 1/4" wider I believe, been a while since I switched mine.
    341
    was that total width or per side?
    Total width.
    May 2013
    124
    Will the Camero or Impala spindles bolt right in a Monte Carlo?
    Yes BUT, because of the camber gain you'll have to move your upper mounts in or go with shorter upper control arms.
