Always on The Rev Limiter?
Always seem to be on the Rev Limiter?
Do you have a race car that hits the Rev Limiter by the time your half way down the straight? Then you have a Rev limiter that is hitting at least 200 rpm early. This issue can be solved by having the Rev Limiter Blueprinted to the 1% Rule. This adjustment eliminates the low condition and puts the Rev Limiter box hitting the chip 20 to 30 rpm above whatever chip is being used. The testing performed for the past two years has shown for every 100 rpm gained back from the adjustment. Will result in the racecar one car length further down the straight before hitting the chip. If your competition has been walking past you last season then you might want to consider getting your Rev Limiter looked at. The cost for your box runs $150, a box can be sourced to be adjusted price will vary depending upon what box is being used. If you have any questions please feel free to contact me. Thank you for looking at this post. www.techwestracing.com
