Results 1 to 3 of 3
    Aug 2014
    Georgia
    688
    Default Best electrical connectors - Posi-Products
    Posi Products are some of the best wire tap and splicing connectors around.
    Never use scotch locks again with Posi-taps. Posi-taps maintain wire integrity and have a lower resistance than scotch locks which makes it ideal in racing electrical. They are also easily removable and will not mangle your wiring like other wire taps.
    Posi-locks are great for connecting two wires together. Simple strip some of the end and slide them into the lock and tighten down. No more crimping like regular butt connectors and no need to cut wiring when you need to replace anything. Just unscrew. Add adhesive backed heat shrink to help waterproof the connection.
    View more info at www.ledfootproducts.com
    Follow us!
    Aug 2014
    Georgia
    688
    Bump.............................................. .
    Aug 2014
    Georgia
    688
    Bump. …………................
    Follow us!
