Results 1 to 7 of 7
    May 2009
    21
    Default Pierce Questions
    Hi, I have done some searching through old post most of which are dated several years ago but I'm sure the information is still the same but want to make sure I have read it all right. Hoping that bob75 will chime in....car number 152 BP U
    Anyways first question is upper control arms, the kid that owned the car before me was known to try some off the wall stuff so I am curious as to what the correct lengths are for the control arms? I don't know if he changed them to try something different or not so would like to know what they came with from the shop.
    Second is more of verification, I know the rearends for these are 60" with a 2" offset. Just want to make sure that I would be right in ordering a 28" tube for the left side and 32" for the right tube.
    Thanks in advance for any help!
    2,814
    I think the tubes are shorter than that , your axle lengths are 28.5. And 32.5', call pierces they can tell you forsure, and a car number 152 like yours is 10.5 left front 7.5 right front if he hasn't changes your mounting points. 815-541-9656. Thanks
    2,814
    Left tube is 22 in. Right tubes is 26 I if any questions call me 815-541-9656
    2,814
    22 in left tube. 26 right axle tubes lengths
    May 2009
    21
    Quote Originally Posted by bob75 View Post
    Thanks for your help! Gets me headed in the right direction. Would you happen to know what year a car with the number would be from? Just curious
    2,814
    Probably 2002 or 03
    illinois
    732
    pierce has a tech line--he can get u any info u need/ 217/354/2972 thanks
