Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: Davenport's car
    Default Davenport's car
    Has anybody got a look at the Brumley device on the left rear ?
    Feb 2008
    117
    Quote Originally Posted by moonshine View Post
    I have. Still don't understand it. I have a few pictures, but out of respect I wasn't posting them.
    Think it adds more bar thrust?
    Dec 2007
    Michigan
    220
    What is it?
    Feb 2008
    117
    It's a bracket attached to the birdcage, with a short little canister shock/with some bumpstops on it. I was at a Lucas race where he wrecked in qualifying, they took it off and put on the back up car.
    Sep 2007
    164
    Where on the birdcage, is it connected? What is the other end attached to? Little more description of installation would be helpful.
    tulsa america
    2,686
    Man this sure sounds like an old bloomer trick. Look over here... not over here.
    Arrow
    Quote Originally Posted by Rayburnt1 View Post
    Sounds like you're describing his travel limiter, they run a biscuit style one, nothing too trick about it.
    Something like this?
    http://pitstopusa.com/i-5081232-ppm-...l-limiter.html
    Jun 2007
    3,123
    As hard as JD runs a car into the corners, I can see where a cushioned travel limiter might help keep the LR from leaving the track on entry. But most people don't like them over a standard chain because it doesn't provide consistent travel. But then again a good driver can work around that. So who knows...
  10. #10
    Nov 2014
    488
    Sounds to me like he is talking about a shock in place of the left top rod. I've considered trying to get n 18 inch canister shock and trying to do it on my car. My shock guy said he's tried it and very hard to tune. Seems like it would be more consistent with bump stops over a spring though
  11. #11
    Could it be like a spring rod set up that they Run on the right side of NE modifieds?
  12. #12
    Batavia, OH
    13,636
    Quote Originally Posted by Punisher88 View Post
    You may be right. My thought was to use bumps too.
    Atomic - 1
  13. #13
    A spring rod doesn't need an extra bracket though. Penske and Bicknell both make shocks for the springrods, hit and miss if you ask me.
  14. #14
    Kansas
    1,940
    Wink
    Billet grins
  15. #15
  16. #16
    Kansas
    1,940
    Sorry figured more people might get it.
    Smoke and mirrors! LOL
    There are several things they are doing slightly different, but I have to say I really don't see any of them being that big of deal or some major advantage. It's a combo of things and they just have everything going for them right now.
    Again going off what I know, could be some stuff I ain't aware of.
  17. #17
    tulsa america
    2,686
    Billet thinks like powerslide
  18. #18
    You're kinda right, they got something but the biggest deal is that the shock engineer(Kevin) is constantly making them better. They have a huge head start with a ton of data acquisition from racing not just practice laps and Kevin knows how to make that work. Not many out here can make that info work for them.
  19. #19
    Jul 2007
    538
    How do you record data during racing? Thought that was against the rules!
  20. #20
    1,903
    Because tech inspectors only check weight , body , tires and engine set back. Unless the car has been ripped apart at the track with independent observers I'm not sure why everyone is soooooo sure its legal ...
