2014 Shaw 35 Series turn key operation for sale. This car has a total of three laps on it. It comes with the very best of everything including Wilwood master cylinders and calipers, light weight front hubs, electric RF brake shut-off, brake adjuster, four gauge panel including a digital tach, Chevelle lowers, Sweet 8:1 steering box, Sweet collapsible steering shaft, Howe ball joints, 22 gallon tear drop fuel cell, Winters QC rear end with gun drilled axles, Keyser bird cages, progressive pull bar, new Landrum springs on all corners, Outpace bars with grease zerks, Bassett wheels, Simpson belts, under car lighting kit, Competitoin Systems, Inc. shocks with covers, BSB eliminator, Butlerbuilt full containment seat, Fast Shaft drive shaft, Jones rear-dive steering pump. Brinn transmission and bell housing, Spec Racing Engines 408 c.i. 23 degree motor with a Willy's "Superbowl" carb set up. The motor made over 690 horse on the chassis dyno. Over $45k invested. A sacrifice at $35k. Retiring from racing. NO TRADES. Located in the Indianapolis area. Phone or text 317-512-5386.
New 2014 Shaw 35 Series
2014 Shaw 35 Series turn key operation for sale. This car has a total of three laps on it. It comes with the very best of everything including Wilwood master cylinders and calipers, light weight front hubs, electric RF brake shut-off, brake adjuster, four gauge panel including a digital tach, Chevelle lowers, Sweet 8:1 steering box, Sweet collapsible steering shaft, Howe ball joints, 22 gallon tear drop fuel cell, Winters QC rear end with gun drilled axles, Keyser bird cages, progressive pull bar, new Landrum springs on all corners, Outpace bars with grease zerks, Bassett wheels, Simpson belts, under car lighting kit, Competitoin Systems, Inc. shocks with covers, BSB eliminator, Butlerbuilt full containment seat, Fast Shaft drive shaft, Jones rear-dive steering pump. Brinn transmission and bell housing, Spec Racing Engines 408 c.i. 23 degree motor with a Willy's "Superbowl" carb set up. The motor made over 690 horse on the chassis dyno. Over $45k invested. A sacrifice at $35k. Retiring from racing. NO TRADES. Located in the Indianapolis area. Phone or text 317-512-5386. QUOTE=Sable1;1945249]2014 Shaw 35 Series turn key operation for sale. This car has a total of three laps on it. It comes with the very best of everything including Wilwood master cylinders and calipers, light weight front hubs, electric RF brake shut-off, brake adjuster, four gauge panel including a digital tach, Chevelle lowers, Sweet 8:1 steering box, Sweet collapsible steering shaft, Howe ball joints, 22 gallon tear drop fuel cell, Winters QC rear end with gun drilled axles, Keyser bird cages, progressive pull bar, new Landrum springs on all corners, Outpace bars with grease zerks, Bassett wheels, Simpson belts, under car lighting kit, Competitoin Systems, Inc. shocks with covers, BSB eliminator, Butlerbuilt full containment seat, Fast Shaft drive shaft, Jones rear-dive steering pump. Brinn transmission and bell housing, Spec Racing Engines 408 c.i. 23 degree motor with a Willy's "Superbowl" carb set up. The motor made over 690 horse on the chassis dyno. Over $45k invested. A sacrifice at $35k. Retiring from racing. NO TRADES. Located in the Indianapolis area. Phone or text 317-512-5386.[/QUOTE]
