Results 1 to 14 of 14
Thread: rr wheel offset
    Default rr wheel offset
    anyone having luck with moving the rr out and actually adding sidebite or keeping the sidebite in the car longer???
    Jun 2013
    307
    To add sidebite to the right rear you would usually pull the rr in towards the car.
    Batavia, OH
    13,634
    Quote Originally Posted by DirtRacer9x View Post
    Yes we tried it with 3" offset, j bar split fairly large and 150-175 rr in at 20-25*. Worked well and didn't cook rr
    Hard to cook a tire with no weight on it.
    Atomic - 1
    Jul 2007
    558
    ive never felt more sidebite by moving RR in, nor liked how it felt.
    Chris Zogg
    May 2015
    856
    What tires are you guys on that are saying more offset is taking away sidebite? If that's the case, I would think you are possibly overloading your RR.
    Lions don't worry about the opinions of sheep.
    chevelle frame,pinto spindles 2 offs on front and left rear.....4 off on right rear with 1" spacer
    Agreed with dirt racer. Makes a big difference on our cae
    May 2015
    856
    Quote Originally Posted by ambonci21 View Post
    tighter/looser? and off/on gas? What tires?
    overall tighter everywhere. Way better side bite. we did it that way on banked tires and flat tracks both big and small. IMCA tires.
  10. #10
    May 2015
    856
    It has more weight on it in further. So of course it has better grip.....Ο
    I thought the topic was less offset, not more.
  11. #11
    May 2015
    856
    Several have posted that less offset made their car tighter. So explain how less weight on RR makes a car tighter???
  12. #12
    It adds more left rear less weight to right rear.Running more offset can loosen off corner because to much weight on right rear
  13. #13
    May 2015
    856
    Quote Originally Posted by anissa5 View Post
    Some have posted that it made entry tighter. That's whats hard to understand when the RR will be less loaded.
  14. #14
    Years ago we use to add wheel spacer to right front and soften the rf spring for entry we did not like to add more offset to right rear but we also ran ump tires. Some cars may transfer more weight then some I always ran a 2 off on right rear
