Results 1 to 6 of 6
    Default Pierce clamp car
    Keep popping left rear spring out of cup last two races what would cause this
    bent clamp bracket letting the car have to much drop
    Ok looked at bracket doesn't seem to be bent how much play should spring have at full drop spring has about an inch before it comes off off clamp bracket
    Has the clamp bracket spun down where the spring sets also is the rearend square
    Doesn't look like it has moved and rear ended is square looks like it might be hitting bolt for short bar on slider mount
    2,814
    Frame height set right, Put longer spring in
