Big List of Stuff
Random Order
2006 Swartz late model chassis and tub, has tub and some brake lines, older bumper and used nose piece. $ 750 or $ 800 with nose below.
Extra front bumper and used but great condition Dominator nose $ 100.
Afco 2.5” ID Coil Over Springs
10” Long 300, 550 (or 500 number partially rubbed off), 450, 400
12” Long 225, 225
14” Long 175, 200, 250
$ 10 Each or all nine for $ 60
Front spindle set, wide 5 late model, tall with short steering arm, unknown brand $ 25 for Both.
Front wide 5 hubs (2), bearings, covers, standard rotors. $ 75 set.
Appleton Rack with Servo, bought used from Crebo Racing Parts, they assured it worked. 19.25” long, 3.4 on it. $ 300.
Brake Pedal, Dual Howe Masters (7/8” and 1” bore) with adjuster $ 125
Winters Quick Change. 4.86 ring and pinion, 35” RR, 32” LR aluminum tubes. $ 250 Bare
$ 300 with Gun Drilled Axles
BSB Quick Change Pinion J Bar Mount, Slider style with spacers $ 100
Wilwood rear wide five hubs, bearings, 8 bolt drive flanges, drilled rotors (2 total) $ 150 for the set.
CV Products Aluminum J Bar, 5 inch Arch, Range about 17 5/8” to 19 3/4” $ 90
BSB J bar Mounts (Frame side) 2” square $ 25
1.5” square $ 15
Steel J-Bar 22”-24” $ 15
Swartz older style (pre 2013 or so) Welded Lift Arm, used for 1 lap then broke driveshaft (has a small ding the upper portion) no cracks, hauled around after as a spare. with brackets. $ 50
Steering Column - 66.75” Long, two U joints, 2 support heims, Hex Disconnect with steering hub. $ 65
Older Liner Birdcages, unknown brand, has 2 brake clamp brackets 3.5” caliper spacer, retainer rings. $ 15
Assorted Birdcage Parts - BSB Liner Cage Barrels, Brake Clamps, Lock Rings (random stuff). $ 15
Steel Birdcage and assorted parts, bob liner mod 4 link cage never used, brake clamps (one metric), stop rings. $ 30
All the Birdcage parts above on box $ 50
Spare Wilwood wide 5 hub, bare $ 5
2 Wilwood calipers, 5.5” mounts, 4 piston fits narrow rotors, not sure if dynalites or what. $ 30 for both.
Willwood Black superlite brake pads, low races on them on axle set, and one axle set of random pads or superlite. $ 30
Afco Swing Arm (short, 12.5” long w/o heim, with heim 14” long) $ 5
2 Aluminum Clevis, for linkages, never used $ 5
2 Battery boxes one 12” wide, one 10.5” $ 15 each
Kirkey 15” Seat with cover, basic seat $ 50
Gauges and Warning lights, 2 fuel pressure (only one works other does not light up), Water temp, Oil, Warning lights, Switch and push button. $ 50
Dominator Plastic Hood Scoop, Carbon Fiber look used but good $ 5
Power Steering tanks, one dented but no leaks other good $ 20 good one $ 10 Dented one
Griffen Aluminum Radiator 19” tall by 24” wide, pinhole repair, no leaks $ 50
Powertrain industries mod driveshaft 32.5” long no yoke $ 50
Edlebrock Alky Fuel Pump SBC $ 10
Carter Gas Pump $ 10
Victor Jr. Intake, good condition $ 200 firm
Bully Chrome Running boards, 68” long, not sure what truck they are for supposed to be ford. $ 50
Hitachi Mini Starter, Block Mount SBC $ 60
CVR Mini Starter, Pro torque Model $ 125
Mini Starter, Cracked mount but works $ 25
2 Carbon Fiber Beadlock 15x12 wheels, 4” BP. $ 100
Homemade spring rater, hydraulic like speedway one, 3000 # capacity, set up for coil overs but can do conventional springs with a sider. Works ok, not fancy. $ 50
SBC Water Pumps (2) Short Aluminum $ 15 each or $ 25 for both.
Moroso Blue Max ignition wires, new in box and never put together. $ 25
Pro-Pan aluminum dry sump pan, has been repaired $ 125
Axles all gundrilled, 37” & 32” for $ 25 each, 35”&34” for $ 40 each or all for $ 100
Snap On 14.4 v impact, 3/8”. Charger broke, tool works just cant recharge so stopped using, still has some charge. rough looking but great tool. $ 50
SBC Wet Sump pan, dual kickouts, dipstick, windage tray, needs good cleaning. $ 100
Fan spacers 2-2”, 1-1.75”, 1-1.5” and 1-1” all for $ 10.
Falcon used coupler $ 10
Metric brake pad spacers $ 5
Bolaws 850 cfm? alky carb apart, I think everything is here, $ 20.
2” Setback steel motor mounts (SBC) $ 5
6 blade 18” fan $ 10
Chrome 14” air cleaner assembly $ 5
3 new american racer tires, never raced, all MD 56 tires, 28.5-11.0-15R, 28.5-11.0-15DTW, and 29.0-11.0-15DTW $ 15 each.
32 gal ATL fuel cell with steel can $ 50.
I have pictures of everything, can get you measurements as needed. Call or text 417-860-4909 or message me. All prices do not include shipping and I will not ship anything that UPS will not take. Please no text or calls after 9pm central.
