Results 1 to 3 of 3
    Mar 2010
    272
    Default 2012 Bernheisel Lazer Rolling Chassis plus spares $8500
    ROLLING CHASSIS W/SPARES……Very nice, clean 2012 Bernheisel Lazer Chassis serial # 1714. Never bent or clipped or damaged in any way. This has been a very consistent top 5 car in crate configuration. Reverse strut right front lower (could be converter to conventional lower).
    Roller Includes for $8500:
    -Frame/(not a nice word)(not a nice word)(not a nice word)(not a nice word)pit/brakelines, white deck, NEW white doors, quarters and filler.
    - All good bumpers/bars/braces – aluminum/spring steel bracing
    - Bolt on Lazer underslung rear carriage
    - Bolt on driveshaft hoop and neutral ballast bar
    - Complete black/diamond front suspension w/Howe low-friction ball joints – 1 pc. RF Lower.
    - Sweet steering rack, double clevis adjustable eyes, 4.25”, .210 servo
    - Wilwood pedals and master cylinders – external mount
    - Wilwood RF electric brake shut-off
    - Willwood dynalite 1.375” front brake calipers
    - Outlaw 1.75” rear brake calipers
    - Wilwood Polymatrix “B” brake pads (all corners) 80% pad life left
    - Wilwood scalloped lightweight brake rotors (1.25”)
    - REM polished bearings w/low drag seals all 4 corners
    - Wilwood starlight hubs
    - Winter’s 4.86 rear – fresh
    - TWM Lazer bearing aluminum birdcages – new bearings 5 races ago
    - Lazer gauge panel w/aero cowl – Accutech/Longacre gauges w/LED bulbs
    - RJS 32 gallon fuel cell w/fuel lines and fuel filter
    - MSD ignition (Lazer ignition panel complete)
    - Remote firewall starter button, all car wiring soldered/heat shrunk, weatherpak connectors.
    - Radiator – single pass w/mount and shroud
    - PPM J-bar, Lazer lift arm, Mini 6th coil.
    SPARE ITEMS INCLUDE:
    - Front suspensions LH/RH (black/diamond) w/ 1pc. RF Lower
    - Spare nose from 2014 season (blue/white)
    - Misc. bumpers/bars/braces
    Also for sale w/car for additional $1200:
    -(6) AFCO 13 series shocks valve for this car w/cups and hardware
    -(5) Integra/Hypercoil springs – for standard setup
    -4 aluminum wheels – 1 beadlock, 3 standard
    -4 tires for transportation
    CALL OR TEXT 717-404-4384
    • File Type: jpg 4m.jpg (157 Bytes, 112 views)
    Mar 2010
    272
    bump to the top
    Mar 2010
    272
    to the top
