430 ci SB2.2 motor fresh @ motor shop Wily's carb, beya tri-y, Barnes 5 stage pump
Selling my race motor. $14,500. A great deal you couldn't begin to put this together for this money and it is fresh. It is an ex Cropper motor and it is fresh, dyno'd and at the motor shop. Call for more details it is a great piece. It is at Peter Gibbons motor sports in Moorseville NC and feel free to call him 704-662-6232 and ask any question you want. Please call me at 704-796-5577. Brodix all aluminum SB2.2 430 ci, Callies Magnum XL 43lbs crank knife edged, 4.000" stroke, BBC snout, Honda Rod, 400 Mains, Carrilo H-Beam Rods, 6.000 Length, .927 SE Honda BE, .940 width, SPS CARR 7/16 rod bolts, CP Flat Top Pistons, Coated Skirts, .927 coated wrist Pins, 4.160" bore, top rings .043 mid .043 oil 3mm, Jesel .904 Roller Lifters, Rollmaster Billet double timing chain, Comp Cam 41345/41365 R108, Clevite H Main and Rod Bearings, Cometic head gaskets, Willy's Carb fresh externally adjustable jets, Beya Tri-Y headers, Barnes 5 Stage Pump with all lines and tank. I can send pictures of everything associated with the motor, it is turnkey and ready to run or put on dyno. Thanks for looking
Just paid to dyno the motor. Being conservative with timing and jetting it pulled 820hp @ 7300 rpm and 680 ft# torque at 5200 and the motor shop said 840-850 isn't out of the question with some tweaking. I have the sheets on the motor. It will look great under the tree, your wife will live it.
