Cutting head
Im a bit confused on if cutting down a head will gain power or stay the same...what are the pros/cons of cutting a head ...also looking to smooth out the bowl( guess its called blending bowls but was told cutting intake and leaving exhaust will help with flow...is this correct
if you mean milling the head then yes, it raises the compression, i usually mill off a minimum of .150 providing that it was a virgin to begin with
www.raceidaho.com
car62
do you prefer blending the bowls? both exhaust and intake?...
www.raceidaho.com
