18 degree 358 Dry Sump
I have a very nice 358. 18 degree aluminum heads, Bowtie steel block, Crower small journal 42lb crankshaft, Carrillo 6" billet rods, Jessel valve train, Peterson 5 stage dry sump pump and lines, Stainless steel drysump pan and lines, MSD dual pick up billet distributor with Scott wires, all aluminum pulleys and mandrals, sheetmetal valve covers with breathers, adjustable #20 water neck, 1" CV Products 4 hole spacer. Engine is very strong and made 703hp with a 830cfm carb. Engine is fresh and ready to drop in. $10,000.00 Engine located in Virginia.
358
Tags for this Thread
