Results 1 to 5 of 5
    Jul 2011
    224
    Default Powerglide input shaft
    Input on running stock vs aftermarket input shaft on a powerglide. 2 barrel imca stock car
    Dec 2008
    139
    I have broken a few in the past and with the way tracks get so ruff it would be worth it to use a aftermarket. You'll be glad you did.
    in a van down by the river
    1,893
    there is also a conversion to use a 350 turbo imput shaft
    they are bigger
    requires modification
    Jan 2011
    217
    I must have been lucky. I ran a direct drive powerglide for 10 years with a stock input shaft and never broke one. Eric
    Jun 2010
    Bakersfield,Ca
    566
    Get the moly. They are new so the clearances are tight on the seal rings, no wear on the bushing area and they are strong. Get the 350 spline. Never worry about it again.
    Gator Engineering
