Results 1 to 9 of 9
    Apr 2014
    8
    Default 3/8th mile gear for 383 - IMCA modified
    I am fairly new to imca modifieds. My car has a fairly stout 383 and with a 6.0 final drive. Will this gear work ok for a 3/8 mile track? I am looking to stay around 6500 to 6800 rpms. I have been told a 6.0 final drive is a good overall gear for most tracks. Will this final drive stay within the above rpm range on a 3/8 mile track? Thanks
    Jun 2007
    140
    Tracks can vary greatly even when called a 3/8. I race on a couple of pretty fast 3/8 tracks and usually run a 5.29 or 5.43 and turn 7-7400 rpm. not sure how much help that is but if you post the track you intend to run someone may have better info for you.
    Depends on the track. Ours is a 3/8 and anywhere from a 5.67 to 6.0 is run. Another 3/8 in south Texas would use a 5.43 to 5.83.
    Oct 2012
    283
    We ran a 5.43 @ Devils Bowl with a well built 383 and AR tires.
    Apr 2014
    8
    Thanks guys. I will be running cotton bowl speedway in Texas. Again, I would like to stay around 6800 rpm. I am assuming 6.0 final dive would put me in 7000 to 7500 range?
    It will. That's what I had when I ran there. I had a 7600 chip in mine and never hit it. I do know, the really fast cars are not running that low of a gear.
    Dec 2008
    226
    If you want to be around 6500-6800 at cottonbowl, you will need to run a 5:67 or 5:83. Also depends on how much lightweight stuff you have in your motor and your cam selection.
    Apr 2014
    8
    If anyone has a 5.43 ratio ford 9" third member, full spool for sale in the Dallas, Ft. Worth area, send me a private message. Thanks
    Oct 2012
    283
    PM was sent
