395 steel head Street Stock/Sportsman engine
My race car friends. If you are needing an engine. Think back a few years when you all got out-run by the 3D car... A PERFECT street stock class engine or even a good modified with steel heads.
We are selling one of our engines that we had back then. Built by N.C. Performance out of Taylorville, Illinois.
It is a 395 CI Chevy nickel block. 4 bolt mains.
Eagle crank
Eagle rods
Mahle flat top pistons
Bullet custom grind camshaft. It is a good one too.
Dart Platinum Iron heads with PBM valves
PBM roller rockers
Stud Girdles
PBM valve springs
Melling oil pump
ARP bolts
Powerband SFI balancer
5/16 pushrods
2 brl Willy's 4412 carb and Phenolic spacer
Clevite bearings
File-fit low tension rings
hex-a-just timing set
2 piece timing cover
coated bearings
Stewart water pump
Starter
Scott Plug Wires
HEI distributor
On one of the most conservative dyno's I have ever saw, it pulled 425 hp @ 6200 and 420 ft. lbs @ 4600. That is about all I know about an engine. It is used but rebuilt 2 races ago. Can see it run on the dyno and take it home for $6500. No block kickers. This is the real deal. And a steal at that... Message me here, or call John at 217-827-5501
