Jet by ERS–2015 MidAtlantic Modified Champ Car-Roller
Priced reduced, needs to find a new racing home! This is the car the Craig "Big Daddy" Ramich raced to the inaugural 2015 MidAtlantic Modified tour championship with feature win at Hagerstown (MD) and most laps led at Path Valley Speedway (PA). Get into a car that you know can run up front! Priced at: $6,750
- Jet Mod (2004, #304) 4-link, metric front; updated by Erwin Racing Supply (2015)
- ERS wide-body with new nose, hood, doors, quarters
- All Outpace rear 4 link bars in the rear, new heims
- All steel-braided fuel lines
- Steel driveshaft
- Optima Red Top battery
- Winters quickchange rear (4.86 ratio)
- Shaw quickchange bracket
- Allstar spring-style third link, dual shaft
- Bilstein shocks all around
- Hypercoil springs all around
- BSB bearing birdcages
- Fuel cell
- BSB coil over eliminator
- Shifter and Shift Linkage
- Quickcar guage package (new this season) including recall tach
- Brake bias adjuster
- Clutch and brake master cylinders
- Steel brake lines
- Collapsible steering shaft with bearing support
- Schoenfeld Jet headers
- Jet engine plate
- Sweet Mfg power steering box (6:1)
- Single-pass radiator
- OEM front steering component (new spares)
- Impala spindles
- Impala lower control arms
- Jet adjustable upper control arms with QA1 ball joints (screw in)
- 4 wheels and tires
- All Jet-related spares (bumpers, lower A-arms, spindles, bars, etc.)
Not included (engine and related components, transmission, seat, belts, MSD/ignition)
Can be purchased as roller or other configurations. Serious inquiries only. Additional photos available upon request.
Contact: Craig Ramich - craig@plusi.com; 571-217-3172
Path Valley most laps led - https://youtu.be/VTSgVJ_xAoY
Feature win at Hagerstown - https://youtu.be/eC5dDi09-Js
Most laps led Path Valley - https://youtu.be/7LYsXLXcMTA
Want to redo the body yourself? Take $750 off the price! Still available in Oilville (west of Richmond), VA
